Creating Menu Item Master Records for Condiments
- Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Menu Item Maintenance.
- Insert a new record, and then enter the condiment name (for example, Ham).
- Search for and then double-click the new record
- Insert a definition record, and then click the General subtab.
- From the Name and Class section, select the Menu Item Class for the condiment.
- To set a priced condiment:
- Click the Prices subtab, insert a price definition, and then enter the Price for the condiment.
- To set the price to become active at a specific menu level, select Active On Level, and then select the level.
- Click Save.
- Repeat Steps 2 through 6 to create menu item master records for all condiments.
Related Topics
Parent topic: Condiments
