Select the Enterprise, property, revenue center, or zone,
click Configuration, and then click Menu Item Classes
Insert a new record, enter the class name, and double-click
the new record.
On the General tab, select the Condiment Order Type from the drop-down list.
This setting describes how the condiment is added to a check
when it is ordered:
0 - Add: Select to create a new item
on the check even if it already exists for that parent.
1 - Increment: Select to add the item
if it does not exist for the parent or increments an existing one.
2 - Replace In Condiment Group: Select
to remove any items that exist in the item’s member condiment group
before adding it (this simulates a radio button effect).
3 - Replace In Master Group: Select
to remove any items that exist in the item’s master group are before
adding it.
4 - Toggle: Select to toggle the item
on and off.
Click the Options tab, and then
select 2 - ON = Condiment Menu Items; OFF = Regular Menu
Items.
When you select this option, Simphony updates the Type column
in table view to Condiment for this menu item class. For a menu item
to be a condiment, it must belong to a class where at least one Member
Condiment Group is enabled.
To set no charge for the condiments in this class, select 8 - Allow Menu Items in this Class to be Non-Priced.
To prevent a condiment from printing on the guest check and
customer receipt if it does not have an associated price, see Configuring Menu Item Classes, specifically
option 79 - Do not print unpriced condiments on Guest Checks.
To set each condiment in this class to print to a specific
order device, select 22 - ON = Use Own Output Link; OFF
= Use Parent's (Condiments Only).
By default, the ideal setup of a condiment group class is
to keep this option deselected and to select all order devices as
the output. This ensures that the condiment always follows the parent
item to its order devices. This option does not apply to Condiment
Prefixes.
To override order device programming of the parent menu
item, select 58 - Condiment order device programming overrides
that of parent.
When this option is selected, order devices configured for
the condiments class override the order devices defined for parent
menu items. Use this option in a situation where a menu item is sent
to a different order device when a specific condiment is added. For
example, a Muffin served at room temperature outputs to the Pantry
Order Device. Warm is set to output to the Hot Order Device. When
the Condiment Warm with this option set is added to the Menu Item
Muffin, the Muffin will use the Order Device output of the Warm Condiment
and go to the Hot Order Device instead of the usual Pantry. This option
does not function if the menu item is a Condiment Prefix.
Click the Condiment Groups tab,
and then select the Member Condiment Groups for the class.
For example, if the condiment class is Deli Meat Class, select
Meat Group from the Member Condiment Groups list.
Click Save.
Repeat Steps 2 through 9 to create menu item classes for
all condiment groups.
