Configuring a Condiment as the Discount Award
- Select the Enterprise, property, or zone, click Configuration, and then click Discounts.
- Create the discount record and then double-click it.
- On the General tab, enter the fields
as described in the following table:
Table 16-11 Discount Fields
Field Description Activation Type
Select the type of discount:-
0 - Manual (Manually entered and applied)
1 - Automatic (Automatically applied, operator cannot enter)
2 - Coupon (Automatically applied, operator must enter)
Percent
Enter the discount percentage to use a percent discount.
Max Amount
Enter the maximum amount allowed for the discount to use an amount discount.
Enabled
Select this option to make the discount available to the workstation operator. (If you configure a temporary discount, you can quickly turn it off.)
Condiment Discountability
Select the discount method for condiment menu items:-
0 - Use MI Class Option: You must also select Menu Item Class option 55 - Discounts Apply to Priced Condiments (parent items only).
1 - Parent Items Only: Selecting this option applies the discount only to the parent menu item.
2 - Condiment Items Only: Selecting this option applies the discount to the trigger condiment and to all condiments associated with the check.
3 - Parent and Highlighted Condiment Items: This option is available only for manual discounts.
4 - Parent and All Condiment Items: Selecting this option applies the discount to the parent menu item and to all condiments associated with the check.
Trigger MI Group
Select the menu item group to trigger the discount award. When a workstation operator adds the minimum quantity of items from this menu item group, the items are discounted based on the award configuration for this discount.
When you select 0 - Use Discount Itemizers, the only options available for the Trigger Condiment Group are 0 - None and all available condiment groups previously created.
Select the Condiment Menu Item Group to use as the trigger for the discount.
This field is dimmed when the Trigger MI Group is set to 0 - Use Discount Itemizers.
This is an alternative method to using discount itemizers. The discount applies to only qualifying menu items based on the selected Trigger Menu Item Group, Trigger Condiment Group, and other discount configuration.
Options
Select 25 - Discount Combo Meal Group Items to discount combo group menu items. You must also select option 1 - Allow Discounts from the Combo Meal Groups module.
- On the Effectivity tab, select the days on which the application applies the discount.
- On the RVC Type tab, select the revenue centers that can use this discount.
- On the Menu Levels tab, in the Menu Level Configuration section, select all options for Active On Main Levels and Active On Sub Levels.
- On the Output tab, select the following
options:
Print on Customer Receipt
Print on Journal
Print on Guest Check
- Click Save.
