Configuring Condiments as Discount Triggers
  1. Select the Enterprise, property, or zone, click Configuration, and then click Menu Item Groups.
  2. Create a menu item group record and then double-click it to open.
  3. Click Add near the Include area.
  4. Select information for the fields described in the following table:
    Table 16-10 Include Fields
    Field Description
    Type
    Select 4 - By Menu Item.
    Start #
    Click in this field, and select the start number.
    End #
    Click in this field, but do not enter a value.
    See Items and Select
    Click the link and then select the condiment to act as the discount trigger. This condiment appears in the End # field.
  5. Click Save.
