Select the Enterprise, property, or zone, click Configuration, and then click Family Groups.
Insert a new record, and then enter a name for the family
group (for example, Appetizers).
Enter a number other than 0 (zero) in the Report
Group field.
For example, you can enter 1 for all family groups associated
with Food and enter 2 for all family groups associated with Liquor.
When you enter 0 (zero), the menu item does not appear on the Menu
Item Report.
(Optional) Select the Parent Major Group to which the new family group belongs.
Assigning a Parent Major Group to a Family Group provides
a filtering of choices when assigning a family group to a Menu Item
Master record, where only the family groups belonging to the assigned
Major Group appear in the drop-down list. This is useful when there
are a large number of family groups configured, or to prevent assigning
a family group which is not associated with a major group.
