PreviousNext
JavaScript must be enabled to correctly display this content
Configuring Major Groups
Select the Enterprise, property, or zone, click Configuration, and then click Major Groups.
Insert a new record, and then enter a name for the major group (for example, Food).
Enter a number other than 0 (zero) in the Report Group field.
For example, you can enter 1 for the Food major group and enter 2 for the Liquor major group. When you enter 0 (zero), the menu item does not appear on the Menu Item Report.
