Configuration Guide Number Look Up (NLU) Configuring Number Look Ups for Discounts Configuring Number Look Ups for Discounts Select the Enterprise or property, click Configuration, and then click Discounts. Double-click a record, and then click NLU/SLU. Enter a unique NLU number for the discount. You can enter a value between 1 and 255. Click Save. Repeat Steps 2 through 4 for all discounts to appear in the number look up. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design. Double-click the transaction page on which you want the number look up to appear on the workstation. Insert a new button, select Function from the Type drop-down list, select Discount NLU from the Function list, and then click OK. Click Save.
