Configuring Number Look Ups for Main and Sub Levels
- Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
 - Double-click the transaction page on which you want the number look up to appear on the workstation.
 - Insert a new button, select Function from the Type drop-down list, select either Main Level NLU or Sub Level NLU from the Function list, and then click OK.
 - Click Save.
