Configuring Menu Item Classes for Pre-Production Chits
You need to determine which menu items to apply pre-production chit printing, navigate to each of these items’ assigned Menu Item Class, and assign the pre-production chit print class. To configure Menu Item Classes to generate pre-production chits:
  1. Select the Enterprise, property, or revenue center, click Configuration, and then click Menu Item Classes.
  2. On the General tab, select the pre-production print class from the Pre-Production Chit Print Class drop-down list.
    Figure 44-1 Menu Item Classes - Pre-Production Chit Print Class Setting
    This figure shows the Menu Item Classes file and the Pre-Production Chit Print Class setting.
  3. Click Save.
