Configuring Print Classes for Pre-Production Chits To configure and assign printers to a pre-production Print Class: Select the Enterprise or property, click Configuration, and then click Print Classes. Insert a new record and enter the name of the pre-production print class in the Name field (for example, Print Pre-Production Chit). Configure settings within the Options section as needed. Select the Routing Group from the drop-down list in the Output section. Typically, enabling the 0 - Use Order Devices routing group suffices for most pre-production chit printing tasks. Enable the order devices that are to serve as a pre-production remote printers. Click Save. Parent topic: Configuring Pre-Production Chits to Output to Remote Printers
