PreviousNext
JavaScript must be enabled to correctly display this content
Setting Stored Value Options
Select the Enterprise, property, or revenue center, click Configuration, and then click Stored Value.
Insert a record, enter Stored Value as the name, and then click OK.
Double-click the record to open it.
Select the appropriate Stored Value Options. The following
table describes the options.
Table 49-7 Stored Value Options
Option
Description
1 - Support Offline Transactions
For a single tenant environment, enable this option to allow
offline stored value transactions.
Stored value transactions
are supported in offline mode only in single tenant environments.
2 - Always Print Stored Value Results
Enable this option to automatically print a chit after each
successful stored value operation. When enabled, upon finalizing a
transaction, the message along with any POS Print Text configured
for the transaction type automatically prints.
3 - Never Display Stored Value Results
Enable this option to require the workstation operator to
tap the workstation to show loyalty results. When enabled, no message
is generated. If the 2 - Always Print Stored Value Results option is enabled, the loyalty results are printed.
5 - Remove Stored Value Results Print Button
Enable this option to hide the Print button from the stored
value results screen. When enabled, the generated message does not
include the Would you like to print? Yes or No prompt. Enable this option in conjunction with the 2
- Always Print Stored Value Results option.
6 - Remove Guest Name Lookup Button
Enable this option to hide the Guest Name Lookup button from the account number entry screen. This option deactivates
the Guest Name Lookup function.
7 - Remove Phone Number Lookup Button
Enable this option to hide the Phone Number Lookup button from the account number entry screen. This option deactivates
the Phone Number Lookup function.
