Configuring the Givex Service Charge Record
You must configure four service charges for use with the
Givex Processor. The service charges are:
Register
Increment
Activate
Points Redeem
- Select the Enterprise, property, or zone, click Configuration, and then click Service Charges.
- Insert a record, name it Givex Register Charge, and then click OK.
- Double-click the record to open it.
- Select option 14 - Service Charge Used For Stored Value Transactions.
- Set other Service Charge fields and options as needed. Configuring Service Charges contains more information about the fields and options.
- Click Save.
- Repeat steps 2 through 6 for the remaining service charges, following a similar naming convention (for example, Givex [SERVICE CHARGE NAME] Charge).
