Configuring the ValueLink Service Charge Record
You must configure four service charge records for use
with the ValueLink Processor for gift card service. The services charges
are:.
ValueLink Activate
ValueLink Batch Activate
ValueLink Activation Return
ValueLink Reload
- Select the Enterprise, property, or zone, click Configuration, and then click Service Charges.
- Insert a record, name it ValueLink Activate, and then click OK.
- Double-click the record to open it.
- Select option 14 - Service Charge Used For Stored Value Transactions.
- Set other Service Charge fields and options as needed. Configuring Service Charges contains more information about the fields and options.
- Click Save.
- Repeat steps 2 through 6 to create the remaining three service charge records.
