Click the Enterprise, Setup tab,
and then CAL Packages.
Select All from the CAL packages
tree.
Click the Deployment Schedules tab.
Click the Add Deployment option.
Click the down arrow under Choose CAL Packages
to upload to access the drop-down list, select WS KDS Display x.x.x, and then select [file name] for
the version of Simphony you are upgrading to. The (xxx) refers to
the version number.
With the Deployment Type set to
the default setting of 1 - Property/Enterprise, click the ellipsis ‘…’ adjacent to the drop-down
list.
Select your property from the list, and then click OK to close the Select Properties list. Click OK again to close the CAL package selection window.
Verify the Action to Take column
shows Install, and then click Save.
Your KDS Displays should begin receiving the KDS Display
update (or at the scheduled time).
