Displaying the Order Chit
After a check is sent, Expo and SOS displays show all items in an order. If Dining Courses are enabled, only items in the current course are displayed.
If the KDS layout includes item statuses, the indicator displayed next to each item shows whether each item has been sent, fired on a prep station, or doned. An additional item status shows when an item has been started.
The following figure provides an example of the status indicators used with item timings.
Figure 8-5 Status Indicators with Item Timings
![This figure shows an example of status indicators that are used with item timings. These icon indicators are a right-facing arrow to show Sent, a dash to show Fired, a circle with no fill color to show Started, and a circle with green fill color to show Done. This figure shows an example of status indicators that are used with item timings. These icon indicators are a right-facing arrow to show Sent, a dash to show Fired, a circle with no fill color to show Started, and a circle with green fill color to show Done.](img/chit_display_item_time.png)
Item timing statuses are also available on Select Electronics, Inc. (SEI) KDS stations. However, because icons are not available, the indicators are shown as follows:
Figure 8-6 Status Indicators on SEI KDS Station
![This figure shows an example of status indicators that are used on SEI KDS stations. These indicators are an X to show Sent, an S to show Started, and a D to show Done. The Fired status does not have an indicator. This figure shows an example of status indicators that are used on SEI KDS stations. These indicators are an X to show Sent, an S to show Started, and a D to show Done. The Fired status does not have an indicator.](img/sei_display_item_time.png)
Parent topic: Menu Item Timing
