Adding a Data Extension Record
  1. Select the Enterprise, click Configuration, and then click Data Extensions.
    Figure 6-3 EMC Enterprise Main Menu
    This figure shows the EMC Enterprise level main menu.
  2. Click the Insert  icon on the toolbar to add a record, enter the Data Extension record name, and then click OK.
    Figure 6-4 EMC Enterprise Main Menu
    This figure shows the Insert Record dialog.
  3. Enter information in the following fields:
    Table 6-1 Data Extension Fields
    Field Description
    Table
    Select 20 - Revenue Center.
    Extra Column Name
    Enter DeliveryPlatformConfigurationData.
    Type
    Select 12 - Json.
    Data Constraints
    Select Max Chars: 9999.
    Sort Priority
    Not applicable; use default value.
    Display Width
    Enter 150.
    Translatable Name
    Translatable Help
    Figure 6-5 Data Extension Module Fields
    This figure shows the Data Extension module records and fields.
  4. Click Save.
