Activating the Delivery Service Provider Interface
WARNING:
Ensure that all configuration has
been completed before activating the delivery platform.
Select the revenue center, click Setup, and then click RVC Parameters.
Click the Interfaces tab, and then
select Delivery Platform Integrations.
In the Delivery Platform Integrations section, select the
delivery platform to enable it.
If you no longer use a delivery platform, disable it.
Click Save.
One hour after activation of the Delivery Platform
Integrations option, the store will be visible and ready
for ordering on the delivery service provider website.
