Configuring Customer-Facing Content
Specify the menu item name, description, and image that customers see in the delivery provider application when placing an order.
- Select the Enterprise, property, or revenue center, click Configuration, and then click Menu Item Maintenance.
- Search in the master records, and then select the menu item from the list.
- Click the Images subtab.
- Enter or change the Consumer Item Name.
- Enter or change the Consumer Item Description.
- In the Image 1 section, click Upload to select the image and upload it to Simphony.
- (Optional) Enter or change the image Title.
- (Optional) Enter or change the image Comments.
- Enter the URL that links to the image.
- Click Save.
