Assigning a SLU
  1. Select the Enterprise, property, or revenue center, click Configuration, and then click Menu Item Maintenance.
  2. Search in the master records, and then double-click the menu item in the list.
  3. Click the General subtab.
  4. In the Touchscreen Properties section, select the relevant SLU from the drop-down lists in SLU through SLU 8.
    You can assign up to eight SLUs per menu item. The SLU number specifies the order in which SLUs appear on the delivery provider ordering site (from least to greatest number). For example, a menu item assigned to SLU 2 will appear in the Entrees category:
    1 Starters
    2 Entrees
    3 Desserts
  5. Click Save.
