POS Clients Running Android Mobile Operating System
You can run Simphony release 2.7 and later on devices that have the Android mobile operating system. The Simphony POS client operates in a similar way on an Android mobile device and a Microsoft Windows device. You can configure the POS client using the EMC.
The UI is the same on all devices and workstations. Android devices have special requirements to consider, including deployment method, configuration requirements, and the procurement process.
The Oracle Food and Beverage Compatibility Matrix contains more information about supported POS client operating systems.
The Client Deployment Guide contains more information about configuring Android devices as workstations.
