For CAPS Workstations
  1. Sign in to EMC.
  2. Click the Enterprise, Setup tab, and then CAL Packages.
  3. Select All from the CAL packages tree.
  4. Click the Deployment Schedules tab.
  5. Click the Add Deployment option.
  6. Click the down arrow under Choose CAL Packages to upload to access the drop-down list, select CAL Client.x.x.x, and then select [file name] for the version of Simphony you are upgrading to. The (xxx) refers to the version number.
  7. Set the Deployment Type to 2 - Specific Service Host from the drop-down list, and then click the ellipsis ‘’ adjacent to the Deployment Type drop-down list.
  8. Select the Check and Posting Service (CAPS) workstation for your property, and then click OK to close the Select Specific Service Host list. Click OK again to close the CAL package selection window.
    Figure 1-7 CAL Packages Add Deployment for a Specific Service Host for CAPS Workstations
    This figure shows the Select Service Host selection window for CAPS workstations.
  9. Verify the Action to Take column shows Install, and then click Save.
    Your CAPS workstation should begin receiving the CAL Client updates (or at the scheduled time).
    The CAPS workstation restarts multiple times while upgrading. Allow the upgrade to run uninterrupted until completed. If you see a failed message during the deployment, stop and troubleshoot immediately. If you see a message showing Local Db Max Size, press OK. You can ignore this message for now, but it is recommended you check the free space on the hard drive of the CAPS workstation after the upgrade is complete.
    See Check and Posting Service (CAPS) in the Oracle MICROS Simphony Configuration Guide for more information.
