Setting and Changing the Default Printer
You can set a default printer when one of the printers is configured for the print job (for example, customer receipt or guest check), that printer is assigned to a printer group, and there is no default printer set for the workstation operator/printer type on the workstation. The default printer selections for the workstation operator/printer type combination automatically reset at Start of Day.
- To set your default printer for the current workstation:
- To change your default printer selection for the current
workstation:
- Click the Change Default Printer Destination button.
- On the Assign Default Destination Printers dialog, select one or more printer types, and then click the Assign Printer button.
- On the Select a Printer dialog, select the printer, and then click OK.
Parent topic: Guest Checks
