17 Workstation Alerts for Unsuccessful Sending to Order Devices
You can enable alerts to notify workstation operators when menu items fail to send to an order device/KDS or kitchen printer. The unsuccessful sending of items can occur:
  • When POS client tablet devices lose wireless network connection. The workstation operator can return to the range of Wi-Fi coverage to ensure that items are sent to the order device/KDS.
  • When the kitchen printer runs out of paper. The workstation operator can add a paper roll to the printer.
  • When the KDS Controller or Print Controller is powered off. The workstation operator can start the KDS/Print Controller.
Important:
A flashing Alerts button appears on the POS client device only when the system does not receive confirmation that an order was successfully sent to an order device/KDS. The workstation operator must then confirm that the items did not reach the kitchen, and notify the kitchen of the items that were not successfully sent. If the order is not successfully received by the KDS Controller, you should consider the order lost, as the order is not automatically sent again once the KDS system’s communication is restored.
