Enabling Workstation Alerts
- Select the property, click Setup, and then click Property Parameters.
- On the Options tab, select 53 - Enable Workstation Alerting.
- Click Save.
- Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
- To configure the Alerts function
key:
- To configure the Show Checks With Failed Prints
To KDS/Order Device function key:
- Open the page on which to place the Show Checks With Failed Prints To KDS/Order Device key.
- On the Edit tab, select the page area in which to define the function key.
- Click Button.
- On the General subtab, enter the function key name in the Legend field.
- Select Function from the Type drop-down list.
- Click the black arrow directly beneath the Type drop-down list, enter Order Device in the Name field, select Order Device, select Show Checks With Failed Prints To KDS/Order Device, and then click OK.
- Click Save.
