- Client Deployment Guide
- CAL Packages
- Configuring CAL Packages
The Simphony subgroup contains the standard packages installed by Simphony.
The Custom subgroup contains the packages added by an administrator.
- Select the Enterprise level, click Setup, and then click CAL Packages.
- Highlight a CAL package.
- Click the appropriate command from the CAL packages tree:
Table 2-2 CAL Packages Tree Commands
Command Description Switch View
Change the grouping of CAL packages from name to version and vice versa. For example, you can view packages belonging only to the Simphony 19.5 release.
Add Custom CAL Package
Upload a CAL package from a local file system to the EMC and database. Uploaded packages appear in the Custom subgroup.
To add a custom CAL package to the EMC and database:-
Create a path on the machine that EMC is being run on: MICROS\Simphony2\EgatewayService\CAL\Win32\Packages\CustomCALPackageName
Place the package files that include a Setup.dat file (where the folder name matches the package name in the Setup.dat file) in the CustomCALPackageName folder.
Open EMC and then navigate to the CAL Packages module.
Select Add Custom CAL Package.
In the CAL Package Location section, navigate to and select the path created in the first step.
The Choose CAL Package to upload and Name fields auto-populate with the name in the Setup.dat.
Click Upload.
The package now appears in the Custom list.
Refresh
Refresh the entire page.
Delete
Delete the highlighted CAL package.
