- Client Deployment Guide
- CAL Packages
- Viewing, Reloading, and Saving CAL Package Contents
- Select the Enterprise level, click Setup, and then click CAL Packages.
- Highlight the CAL package, and then click the Package Contents tab. The Platforms section lists all available platform types, the Setup.dat version, and CAL package name.
- From the Files list, select a platform
to see all files included in the package.
To open the file in Notepad, click View Selected File.
To reload the entire CAL package for all platforms and files from the specified file location, click Reload Package From Disk. You must be signed on with the same hierarchy level as the CAL package to see this command.
After you modify an existing default or custom package, reload the package. Ensure that the Setup.dat version matches the file before it loads to avoid reloading the package on all POS clients.
After installation and when the load balanced address changes, replace the local machine with the load balanced address in SimphonyInstall.xml, and then reload the entire package.
To save the entire CAL package for all platforms and files to the specified file location, click Save Package To Disk, select an empty output folder, and then click OK.
