2 Deliveroo
Decide on your menu. Deliveroo supports one menu.
Decide on a unique tag name for the menu.
Plan the list of menu items.
Determine menu availability. For example, will the menu be available only on weekdays between specific times?
The menu can have multiple categories but must have at least one category. A category is a group of similar menu items. For example, you can have a lunch menu with categories for salads, sandwiches, and desserts.
In Simphony, a category corresponds to a SLU. Each category needs its own SLU.
Deliveroo supports a maximum of 100 SLUs. -
Decide on an image to display for the menu. This is required. You can upload the menu image to the Oracle Object Store through a dummy menu item.
Consider the following characteristics of each menu item:
Customer-facing menu item name
Deliveroo menu sync does not accept menu item names which contain fewer than two characters. This can cause issues when using the Chinese language. -
Customer-facing menu item description
Menu item image that meets the following specifications:
JPEG or PNG file format
Pixel size of 1920 x 1080
Aspect ratio of 16:9
Menu item price
Allergen classes
Consider the display of menu items on delivery platform ordering sites and kiosks, and determine whether advanced menu options are needed:
Price sequence level filter
Condiment group filter
Image slot
SLU slot
- Registering with Deliveroo
- Transaction Services Generation 2
- Creating Tender Media
- Creating Order Types
- Configuring an Open Discount
- Creating a Deliveroo Employee
- Adding a Data Extension Record
- Configuring Currency Settings
- Configuring the Language Culture
- Creating Allergen Classes
- Creating Menu Tags
- Creating Screen Look Ups for Menu Items
- Configuring Menu Items
- Configuring Advanced Menu Item Options
- Creating Delivery Configuration in the Revenue Center
- Activating the Delivery Service Provider Interface
- Verifying Setup
