Activating the Delivery Service Provider Interface
WARNING:
Ensure that all configuration has been completed before activating the delivery platform.
  1. Select the revenue center, click Setup, and then click RVC Parameters.
  2. Click the Interfaces tab, and then select Delivery Platform Integrations.
  3. In the Delivery Platform Integrations section, select the delivery platform to enable it.
    If you no longer use a delivery platform, disable it.
  4. Click Save.
    One hour after activation of the Delivery Platform Integrations option, the store will be visible and ready for ordering on the delivery service provider website.
