SLU Slot
The Screen Look Up (SLU) slot lets you specify which SLU slot is used for the product display in delivery service providers. By default, the system shows all SLUs assigned to a menu item as categories in the delivery service provider. If multiple SLUs are in use for an organization, the SLU slots appear as multiple categories with the source product displayed in each SLU. The selection allows customers to specify the SLU name to use as a category name in their delivery service provider.
See Sample JSON: Uber Eats for a description of JSON data values and a code sample that you can copy and change for your restaurant.
Parent topic: Configuring Advanced Menu Item Options
