3 People and Privileges
In Simphony, privileges determine the activities an employee can perform, the EMC modules available to the employee, and the types of transactions the employee can process. You can configure privileges by the job role (for example, host, server, bartender, cashier, manager).
Simphony 19.6 or later with Reporting and Analytics 20.1.15 or later
Simphony 19.5 or earlier
Simphony 19.6 or later with Reporting and Analytics 20.1.14 or earlier
If you are using Oracle MICROS Labor Management with Simphony 19.5 or earlier, you need to add employees using Labor Management. The Oracle MICROS Labor Management User Guide, located on the Oracle Help Center, contains information about adding employees in Labor Management. The initial employee information is sent from Labor Management to Simphony.
