Stored Value Solutions (SVS) Processor
The SVS Processor is an extension to the XProcessor Extension Application. It provides access to the SVS gift card service. This section describes how to configure the SVS XProcessor plug-in.
Here is a listing of the supported operations for the SVS Processor:
![This figure shows the data workflow from the workstation’s service host running POS Operations to the SVS Host. A workstation operator presses a specific gift card operation button in POS Operations, and this triggers logic in the XProcessor Extension Application, which triggers the SVS Processor logic, which then communicates with the hosted SVS Web Service. This figure shows the data workflow from the workstation’s service host running POS Operations to the SVS Host. A workstation operator presses a specific gift card operation button in POS Operations, and this triggers logic in the XProcessor Extension Application, which triggers the SVS Processor logic, which then communicates with the hosted SVS Web Service.](img/SVS_data_workflow.png)
Activate
Authorize
Cash Out
*Optional - Enable Bonus Gift Card
Finalize
Inquire
Issue
Redeem
Reload
Void Reload
Figure 41-7 SVS Processor Data Flow
Setting up the SVS Processor consists of adding or modifying records
in the following EMC modules:
Content
Interfaces / Payments module
Page Design
Service Charges
Tender/Media
If you are an existing SVS customer, you can continue using your SVS Processor configuration, but you must be using the latest release package, which is Version 1.2.2.22.
