Configuring the SVS Discount Record
You must create a discount record for use with the SVS Processor plug-in for the gift card service. The discount is used to implement the optional SVS Bonus Gift Card.
- Select the Enterprise, property, or zone, click Configuration, and then click Discounts.
- Insert a record, name it SVS Bonus GC Redeem, and then click OK.
- Double-click the record to open it.
- Set other Discount fields and options as needed. Configuring Discounts contains more information about the fields and options.
- Click Save.
Parent topic: Stored Value Solutions (SVS) Processor
