ValueLink Processor
The ValueLink Processor is an extension to the XProcessor Extension Application. It provides access to Fiserv’s ValueLink gift card service. The processor communicates with Fiserv’s (formerly FirstData) ValueLink Host either by Fiserv’s Secure Transport or Frame Relay via TCP/IP.
Figure 41-15 ValueLink Processor Data Flow
![This figure shows the data workflow from the workstation’s service host running POS Operations to the ValueLink Host. A workstation operator presses a specific gift card operation button in POS Operations, and this triggers logic in the XProcessor Extension Application, which triggers the ValueLink Processor logic, which then communicates with Fiserv’s Datawire or Secure Transport Service to Fiserv’s ValueLink Host. This figure shows the data workflow from the workstation’s service host running POS Operations to the ValueLink Host. A workstation operator presses a specific gift card operation button in POS Operations, and this triggers logic in the XProcessor Extension Application, which triggers the ValueLink Processor logic, which then communicates with Fiserv’s Datawire or Secure Transport Service to Fiserv’s ValueLink Host.](img/valuelink_data_workflow.png)
Setting up the ValueLink Processor consists of adding or modifying
records in the following EMC modules:
Content
Page Design
Payments
Service Charges
Tender/Media
If you are an existing ValueLink customer, you can continue using your ValueLink Processor configuration, but you must be using the latest release package, which is Version 2.10.0.9997.
