Select the Enterprise, property, revenue center, or zone,
click Configuration, and then click Page Design.
Open the page on which to place the memo check button.
On the Edit tab, select the page
area in which to define the buttons.
Click Button, and then on the General
subtab, select Function from the Type drop-down list.
Click the black arrow beneath the Type drop-down list, and then select Guest Seat from the Type pane.
Select one of the following function keys, and then click OK:
Manage Seat Filter: A pop-up screen
appears showing all available seats on the guest check, and lets you
add or remove seats interactively from the seat filter.
Add to Seat Filter: Prompts you for
a seat number that is to be filtered (if no seat filter is active),
or adds the seat number to an active seat filter.
Remove From Seat Filter: Prompts you
for the seat number that you want to remove from the current seat
filter.
Clear Seat Filter: Removes all seats
from the current seat filter.
Edit Seat: Allows you to change the
seat number of previously ordered menu items.
Enter a Legend for the button, and
then position and size the button on the page.
Repeat Steps 3 through 6 and create buttons for the remaining
functions in Step 6.
