26 Workstation Touchscreen Pages
A touchscreen page is a defined layout of functions and buttons that you configure using the Page Design module in the EMC. The touchscreen page appears on the workstation, allowing workstation operators to perform operations and transactions on the POS client.
Classic templates: These templates are similar to Simphony First Edition touchscreen templates
Blank templates: These templates are used for customized pages or a Sign On page
Tabbed templates: These templates are used for Sign On and Transaction pages
Tabbed templates allow the greatest functionality. With a tabbed template, you can configure multiple tabs on the page. Approximately 50 tabs and subtabs can appear on a page, and each tab and subtab contain up to 50 buttons. Having a large number of buttons on a single page allows you to configure a small number of pages for a revenue center. A tab is used for navigation. Navigation on a page is consistent from page to page (navigation bar and subtabs).
When working with tabbed templates, and you add navigational tabs to a page, and then you want the tabs to only be visible based on a condition (or multiple conditions), the tabs show on the POS workstation screen when any of the conditions are met. In other words, if you configure multiple conditions for tab visibility, if any one of the conditions are met, the tab shows on the POS workstation screen.Pages can contain buttons and more sophisticated content, such as dining tables, Screen Lookups (SLUs), numeric entry areas, and background panels for highlighted groups of controls. All buttons perform a function.
The content appearing on a page can be dynamic based on the menu levels, serving period, employee class, or other criteria. For example, you can show a Manager Functions tab only if the manager is assigned to one of three manager employee classes.
- Screen Look Up (SLU)
- Number Look Up (NLU)
- Page Design
- Assigning Default Touchscreen Pages
- Configuring a Custom Page Template
- Configuring Function Keys
- Adding the Menu Item Availability Key to the Transaction Page
- Adding Menu Item Keys to the Transaction Page
- Adding the Edit Menu Item Key to the Transaction Page
- Configuring a Workstation’s Touchscreen Aspect Ratio
- Configuring Macros
- Configuring a Smart Key on a Workstation
- Mobile Handheld Page Templates with Full Width Check Detail Area
- Configuring a Local Pop Up Menu for Mobile (HHT) Touchscreens
