Adding Menu Item Keys to the Transaction Page
- Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
- Open the page (typically the Transaction page) on which to place the menu item buttons.
- On the Edit tab, select the page area in which to define the menu item buttons.
- Click Button to add a button.
- On the General subtab, enter the button name in the Legend field.
- From the Type drop-down list, select Menu Item.
- Click the black arrow beneath the Type drop-down list.
- Select the menu item, and then click OK.
- From the Menu Item Display Name drop-down list, select the appearance for the menu item name.
- Position and size the button on the page. Use the Style arrow to change the color.
- Click Save.
- Repeat Steps 4 through 11 to create keys for each menu item.
Related Topics
Parent topic: Workstation Touchscreen Pages
