Page Design
When you manually change template field heights and widths in the Page Design module, the settings are supported with the HTML5 UI that is used for Linux workstations and Android devices, in addition to Windows devices. This enhancement allows you to use the same Page Design templates when you have a variety of device platforms. Page templates only need to be configured once and can then be used on Windows, Linux, and Android devices without reconfiguration.
The following manual template size settings in Page Design support
the HTML5 UI:
Tab Item Width
Tab Item Height
Top Status Bar: Height
Bottom Status Bar: Height
Last Entry Area: Font Size (affects the Height)
Navigation Bar Font Size
Navigation Bar Text Alignment
Attention:
The custom page name length can affect saving the custom page configuration. If the Simphony EMC shows an error when trying to save, shorten the page name length until the configuration is saved.Related Topics
Parent topic: Workstation Touchscreen Pages
