Configuring Number Lookups for Menu Items
You can create NLUs for retail menu items (for example, bottled wine, t-shirts, and hats).
- Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Menu Item Maintenance.
- Double-click a menu item, and then click the General tab.
- Select the relevant NLU Group from the Number Lookup Properties section.
- Enter a unique NLU Number for the menu item. Up to 12 digits are allowed
- Click Save.
- Repeat Steps 2 through 5 for all menu items to appear in the number look up.
- Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
- Double-click the transaction page on which you want the number look up to appear on the workstation.
- Insert a new button, select Function from the Type drop-down list, select Menu Item NLU from the Function list, and then click OK.
- Click Save.
