Configuring a Revenue Center to Use the Popup Condiment Orderer
- Select the revenue center, click Setup, and then click RVC Parameters.
- From the Default Condiment Ordering Popup drop-down list, select the default Popup Condiment Orderer Page to appear when the workstation operator adds a menu item with required condiments for the revenue center.
- From the Default Condiment Editing Popup drop-down list, select the default Popup Condiment Orderer Page to appear when the workstation operator selects a menu item with required condiments in the check detail area for the revenue center.
- Click Save.
Related Topics
Parent topic: Popup Condiment Orderer
