Popup Condiment Orderer
The Popup Condiment Orderer provides a screen workflow that automatically advances the workstation operator through required condiments when adding menu items.
The Popup Condiment Orderer resides in a template. The system creates a page (based on the template) that pops up for required condiments. When adding a menu item (for example, Steak) that requires condiment selection to a transaction, the page with the template appears as a popup where the workstation operator can select the required condiment groups (for example, meat temperature and sauce).
The workstation operator can also recall a Popup Condiment Orderer to modify the required condiments of a previously ordered menu item. The workstation operator can select the parent item or condiment in the check detail or select the Recall Popup Condiment Orderer function key (depending on configuration).
Unlike the regular Condiment Orderer, the Popup Condiment Orderer automatically pops up and closes.
Configure a Popup Condiment Orderer page
Configure a revenue center to use the Popup Condiment Orderer
Configure a menu item class to use the Popup Condiment Orderer
