An employee with the event types privileges can configure event types and sub types.
Select the Enterprise level, click Setup, and then click Event Types.
Insert a record for the event (for example, Baseball Double Header or Social), and then click OK.
Double-click the event record to open it in form view.
To create event sub types related to the event type, in the Event Sub-Types section click Add, and then enter an event sub type name (for example, Baseball Game 1, Baseball Game 2, or Wedding).
To delete an event sub-type, highlight the Event Sub-Type, and then click Delete in the Event Sub-Types section.
(Optional) Select the Menu Level Link and the Sub Level Link to associate with the event type. You must select a main menu level before you can set a sub menu level.
When you assign main or sub levels to an event type, the event transactions at the POS client use these menu levels rather than the default levels. This configuration is useful when a venue and customer agree to a specific pricing level for the event type. For example, a Happy Hour menu level can be set for an event type of Social. This configuration allows a wedding event to apply Happy Hour prices at the workstation, overriding default menu levels set at the revenue center level.
