Enabling Events
You need to enable events to associate transactions with events and to use event reporting.
  1. Select the property, click Setup, and then click Property Parameters.
  2. Click the Options tab, and then select 51 - Enable Events Reporting.
  3. Click Save.
    When option 51 - Enable Events Reporting is enabled , users should expect to be prompted for each newly opened check at point-of-sales (POS) workstations. If Control Parameters option 67 - Association of an Event to every Guest Check is mandatory where Event is enabled is disabled, from the Select Check Event window, click None and then Ok to proceed with the order. If option 67 is enabled, users are required to choose an Event, or if no Event currently exists, users receive a No events to select message prompt.
