Breaking Linked Events
There are two methods you can use to break the link of events, each producing a different outcome for the events:
Break the link between the last linked event and its parent, making the last event the parent event
Change a linked event to become the parent event, with subsequent events as the new parent’s linked events
- Select the property, click Configuration, and then click Event Definitions.
- Double-click the event record to open it in form view.
- Click the Links tab.
- To break the link between the last event and its parent:
- Click the Break Link link.
- Click Yes at the confirmation. The last linked event in the list is removed, and it now appears in the Event Definitions module search/table view as a parent event.
- To change a linked event into a parent event:
Related Topics
- Configuring Event Privileges and Permissions
- Specifying Ad Hoc Reports
- Enabling Events
- Configuring Event Types and Sub Types
- Creating an Event
- Configuring an Event Area
- Linking Events
- Cancelling an Event
- Configuring Event Information to Print on Checks and Receipts
- Creating Task Schedules
- Configuring the Event Status Bar
- Configuring the Event Buttons
- Event Information in Reporting and Analytics Reports
Parent topic: Linking Events
