Configuring the Loyalty Module Select the Enterprise, property, or revenue center, click Setup, and then click Loyalty Module. Insert a record, enter LoyaltyModule as the name, and then click OK. If you are using Valutec, you can name the module record VTLoyaltyModule. Double-click the record to open it. On the General tab, click the Import from a file link. Browse to [Drive Letter]:\MICROS\Simphony2\EgatewayService\handlers, select LoyaltyCommandModule.dll, and then click Open. If you are using Valuetec, select VTLoyaltyCommandModule.dll, and then click Open. Click the Configuration tab. In the Assembly/Class section, enter information in the following fields: Module ID: Enter a value that identifies the module. For Valutec, enter VTLoyaltyModule. Display Name: Enter a name for the module (for example, Loyalty or VTLoyalty). Description: Enter a description of the loyalty module. Do not leave this field blank. In the Common Properties section, enter information in the following fields: Currency ISO Code: Enter the code (three alpha characters) that represents the currency being used (for example, USD). See http://www.currency-iso.org/en/home/tables/table-a1.html for a list of Currency ISO 4217 codes. Language ISO Code: Enter the code (two alpha characters) that represents the language being used (for example, EN). See http://www.loc.gov/standards/iso639-2/php/code_list.php for a list of Language ISO 639-1 codes. If the currency or language is different at the property, override these values at the property level. In the Loyalty Module Properties section, enter information in the following fields: Account Number Maximum Length: Enter the maximum length of a loyalty account number (up to 24 digits). Account Number Minimum Length: Enter the minimum length of a loyalty account number (down to 7 digits). Cash Module Name: Enter the name of the cash module to use for redemptions (for example, Cash:Cash). Click Save. Select the property, click Setup, and then click Loyalty Driver. Double-click the gift and loyalty driver record to open it. Click the Override This Record link, and then click Yes to confirm. Click the Configuration tab. From the iCare Driver Properties section, enter information in the following fields: Login: Enter the login for the property ID or the login for the provider. Password: Enter the password for the property ID or the provider. Click Save. Related Topics Loyalty and Stored Value Configuration Prerequisites Configuring Loyalty and Stored Value Privileges Setting Loyalty Options Configuring the Loyalty Driver Creating Loyalty and Stored Value Buttons Voiding Points on a Re-opened Check Loyalty Configuration Tasks Parent topic: Loyalty Configuration Tasks
