Select the Enterprise, property, or revenue center, click Configuration, and then click Loyalty.
Insert a record, enter Loyalty as
the name, and then click OK.
Double-click the record to open it.
Select the appropriate Loyalty Options as described in
the following table.
Table 40-3 Loyalty Options
Option
Description
1 - Support Offline Transactions
Disable this option as loyalty transactions are not supported
in offline mode.
2 - Always Print Loyalty Results
Automatically prints a chit after each successful loyalty operation. When enabled, upon
finalizing a transaction, the message along with any POS Print Text configured for the
transaction type automatically prints.
3 - Never Display Loyalty Results
Requires the workstation operator to touch the workstation in order to show loyalty results. When
enabled, no message is generated. If the 2 - Always Print Loyalty
Results option is enabled, the loyalty results are printed.
5 - Remove Loyalty Results Print Button
Hides the Print button from the loyalty results screen. When enabled, the generated message does
not include the Would you like to print? Yes or No prompt.
Enable this option in conjunction with the 2 - Always Print Loyalty
Results option.
6 - Remove Guest Name Lookup Button
Hides the Guest Name Lookup button from the account number entry screen. This option deactivates
the Guest Name Lookup function.
7 - Remove Phone Number Lookup Button
Hides the Phone Number Lookup button from the account number entry screen. This option
deactivates the Phone Number Lookup function.
8 - Use Loyalty Account for Stored Value
Uses the guest loyalty account for stored value card transactions on the check.
To create a separate button that always prompts for the stored value card account,
even if a loyalty account is already present, create another record and do not enable
this option for the new record.
