Configuring Menu Item Prices
- Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Menu Item Maintenance.
- Click Search to show all menu items, and then double-click a menu item master record.
- Click Prices, and then click the Insert button on the toolbar.
- From the Prices to Add field, select Price Sequence #1, enter the Default Price for the menu item, and then click OK.
- Configure the price record. The following table describes
the price record fields:
Table 17-10 Price Record Configuration Fields
Field Description Price
Enter the menu item price amount.
(Optional) Prep Cost
Enter the menu item prep cost.
This field is grayed out for properties that have Inventory Management enabled.
Tax Class Override
To allow the menu item price to use a different tax class than the tax class configured for the menu item definition, select a new tax class from the list.
If you select 0 - None, the price uses the tax class configured for the menu item class associated with the menu item definition.
Service Charge Group
If the price includes a service charge, select a service charge group from the list.
Active on Level
Select the main or sub menu level in which this price becomes active.
Select 0 - All Levels to make the price active for all menu levels.
Effectivity Group
To make the price active at a specific date and time, select the corresponding effectivity group from the list.
Effectivity Status
Shows the current availability of the price record based on the record's effectivity group setting.
- Click Save.
- Repeat Steps 3 through 6 to add price definitions for the
menu item.
See Configuring and Enabling Effectivity Groups for more information.
Parent topic: Menu Item Prices
