Posting Checks to the Channel Management Dashboard
If configured for your organization, you can enable the posting of checks from Simphony Essentials to the channel management cloud so that the checks will appear in the dashboard.
- Select the Enterprise, click Setup, and then click Enterprise Parameters.
- Click the Applications tab.
- To enable the posting of checks to the Channel Management Dashboard from Simphony workstations, select Enable Channel Management.
- Click Save.
Parent topic: Order Channels
