Configuring Order Channels to Appear on POS Workstation Devices and Reports
You can configure an order channel to appear on Property and Employee Financial Reports
- To control the appearance of an order channel on the POS
and in the workstation Journal Report:
- To configure an order channel to appear on Property, Employee,
and Revenue Center Financial Reports:
- Select the Enterprise or property, click Setup, and then click Report Parameters.
- Click the Options tab.
- To enable printing the order channel section on financial reports, select 12 - Print Order Channel Breakdown on Financial Reports.
- Click Save.
Parent topic: Order Channels
