Configuring a Touchscreen Button to Pick Up Checks by Order Channel
You need to configure a button for workstation operators to pick up open checks by order channel on the POS client device.
- Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
- Open the page on which to place the pickup check by order channel button, and then on the Edit tab, select the page area in which to define the button.
- Click Button.
- To configure a pickup check by order channel button:
- On the General subtab, select Function from the Type drop-down list
- Click the black arrow directly beneath the Type drop-down list, select the function Pickup Check From List Prompt Order Channel, and then click OK.
- Enter a Legend for the button, and then position and size the button on the page.
- Click Save.
Parent topic: Order Channels
