Select the revenue center, click Setup, and then click Order Devices.
Double-click a printer order device record, and then click
the Options tab.
Select the appropriate options that apply to secondary
printing, and then click Save:
16 - Print Secondary Items: Select this
option to allow this order device to print items sent from other printers
as secondary items.
17 - Broadcast Secondary Print Jobs to All Printers: Select this option to send all items programmed to print at this
order device to other printers to print as secondary items. Items
print only at other printers that have 16 - Print Secondary
Items enabled.
18 - Print Secondary Printer Header:
Select this option to print the name of the printer from which the
secondary items are being broadcasted.
19 - Print Secondary Items in Red: Select
this option to print secondary items in red.
20 - Suppress Blank Lines Between Secondary Items: Select this option to remove extra line spacing between secondary
items on order chits.
